vinodhsaminathan
Junior Member level 2
I read the below sentence in a document. i am unable to understand how to land a signal on top of n-well.can anyone explain pls?
For signals going to a sensitive block, land them first, on top of an n-well and then use a via-bridge and then take them further. This helps to reduce unwanted coupling between block.
Also explain what is high speed analog layout pls?:-(
