how to read the current value of the MHz circuit branch
no4baseman
i test a power amplifier which operates at 10MHz, and i wanna read the current value of a branch, but i don't have any instrument except a multimeter. Then,the branch exists inductance.
i wanna know whether the multimeter is in series with the branch, whose current is about several amps, is feasible .
Or a small resistor, for example 1 ohm, is in series with the branch, and i read the voltage of the resistor. is the method feasible?
Thank you first!
A typical multimeter won't respond to 10 MHz. It will probably read very low or zero.
A good solution is to use an oscilloscope with a current probe as artem suggested. If you don't need to measure DC current, you could use a wideband current monitor instead of a current probe. Here are some nice ones. They cost several hundred US dollars.
Crazy idea - If you are in Antarctica or someplace where you can't get an RF power meter, oscilloscope, or anything that measures 10 MHz, maybe you could compare the temperature of the 1-ohm series resistor to another identical resistor heated by a DC power supply. Be sure to use a non-inductive resistor.
