How to pass LVS using Spice netlist while using TSMC IO Libraries
okolhe
Newbie
Hello! I am working with TSMC 180nm IO Library. They have provided me with GDS, SPI and LEF files. How do I use these files to pass LVS in Cadence.?
Can I create a schematic and symbol view from these files or should I include these files while performing LVS?
Thanks in advance for the help.
Regards,
Om
First thing, add Cadence pins appropriately to the streamed-in
layout. Without those correspondence-points, anything complex
will probably just fail for confusion.
Your customer should have some kind of schematics. Maybe
from a non-Cadence source. You should ask for whatever is at
hand (PDF plots w/ properties visible, EDIF, a SPICE netlist?)
that will let you (re)capture schematics that "should" match.
