ammassk
dear all,
I have written a code as shown below. I couldn't make it synthesazable. I don't understand how to make it synthesizable also. PLease help me to do the same.
/code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity bitnode is
port(clk,wr:in std_logic;
op0,op1,op2,op3,op4,op5,op6,op7,op8,op9,op10,op11,op12,op13,op14,op15ut std_logic_vector(15 downto 0));
end bitnode;
architecture Behavioral of bitnode is
signal m,n:integer;
type rowarray is array(0 to 15)of std_logic_vector(15 downto 0);
signal rowmem:rowarray;
type bitarray is array(0 to 15)of integer;
signal node:bitarray;
type array1 is array(0 to 7)of std_logic_vector(15 downto 0);
signal we:array1;
type array2 is array(0 to 7)of std_logic_vector(15 downto 0);
signal pr:array2;
signal done:std_logic;
begin
process(wr)
begin
if wr='1' then
node(0)<=1;
node(1)<=3;
node(2)<=4;
node(3)<=7;
node(4)<=0;
node(5)<=1;
node(6)<=2;
node(7)<=5;
node(8)<=2;
node(9)<=5;
node(10)<=6;
node(11)<=7;
node(12)<=0;
node(13)<=3;
node(14)<=4;
node(15)<=6;
rowmem(0)<="1111101111000001";
rowmem(1)<="1111010001110111";
rowmem(2)<="1111101111000001";
rowmem(3)<="1111101111000001";
rowmem(4)<="1111101111000001";
rowmem(5)<="1111101111000001";
rowmem(6)<="1111001110111110";
rowmem(7)<="1111101111000001";
rowmem(8)<="1111001111110010";
rowmem(9)<="1111001111110010";
rowmem(10)<="1111001111110010";
rowmem(11)<="1110101111001010";
rowmem(12)<="1111010001110111";
rowmem(13)<="1111010001110111";
rowmem(14)<="1111001111110010";
rowmem(15)<="1111010001110111";
done<='1';
end if;
end process;
process(clk)
--type zarray is array(0 to 7)of std_logic_vector(15 downto 0);
variable z:array1;
--type warray is array(0 to 7)of std_logic_vector(15 downto 0);
variable w:array2;
variable p:integer:=0;
begin
if(clk='1' and clk'event)then
if (done='1')then
for m in 0 to 15 loop
for n in m+1 to 15 loop
if(node(m)=node)then
z(p):=rowmem(m);
w(p):=rowmem;
p:=p+1;
if(p>7) then
p:=0;
end if;
end if;
end loop;
end loop;
end if;
end if;
we<=z;
pr<=w;
end process;
end Behavioral;
/code
/code
library IEEE;
entity bitnode is
end bitnode;
signal m,n:integer;
signal we:array1;
signal pr:array2;
begin
process(wr)
begin
if wr='1' then
node(0)<=1;
node(1)<=3;
node(2)<=4;
node(3)<=7;
node(4)<=0;
node(5)<=1;
node(6)<=2;
node(7)<=5;
node(8)<=2;
node(9)<=5;
node(10)<=6;
node(11)<=7;
node(12)<=0;
node(13)<=3;
node(14)<=4;
node(15)<=6;
done<='1';
end if;
end process;
process(clk)
variable z:array1;
variable w:array2;
begin
if (done='1')then
z(p):=rowmem(m);
w(p):=rowmem;
p:=p+1;
if(p>7) then
p:=0;
end if;
end if;
end loop;
end loop;
end if;
end if;
we<=z;
pr<=w;
end process;
end Behavioral;
/code
