How to have analogue output from 0 to 15 volts
riz_raxi
Junior Member level 1
Dear Sir,
I am having AD/DA PCF 8591 Chip and i am trying to get variable output voltage from range of 0 to 15 volts. But i am not able to do so.
Is there any way of getting output voltage variable between 0 to 15 volts.
Please help.
Thankyou
whats the output of your DA?
If it is 0...5V then us a noninverting OPAMP circuit with gain of 3.
Klaus
In the datasheet at page 7 is mentioned what are the settings to get the required output voltage, following a specific equation.
Klaus
My output is from 0 to 15 volts variable.
How it can be used for variable output voltage.
I just want to know how to do communication with arduino usign i2c communication. I mean what address 0x90 > 1 stands for and what are the series and sequence of sending the bytes in order to get specific voltage ranging from my reference voltage 0 to 15 Volts.
max VRef input of PCF8591 is VDD. max. operating voltage of VDD is 6V.
Don´t use 15V as Ref.
I2C:
The device specific information you can find in the datasheet.
Global I2C description you may find at philips NXP homepage.
Klaus
