how to give the 16 bit input on fpga kit on spartan 3E??????
abhi_459
Member level 3
Member level 3
chd india
how to give the 16 bit input on fpga kit on spartan 3E.
can anyone tell me plz......
"give the 16 bit input"? Please clarify your question.
Re: how to give the 16 bit input on fpga kit on spartan 3E??
in my entity inputs are 16 bit std_logic_vector.and in spartan 3E kit only 8 switches are avaliable for 8 bit input,....so how can i give the input which is greater than 8....
Does the board have expansion connectors?
If so, attach extra switches to the board using the expansion connectors.
hi,
tkbits has right. You can attach to j2 connector(4 inputs) and j1 conector(4 inputs) extra swithes or buttons.
B.
if you use xilinx then in source window keep implementation /synthesis then in process window design utilities click the + mark. and give assign package pins.if you have spartan 3e kit manual there will be pin no for switches. enter the no in window which is opened while clicking yhe assign package pins.
