Re: how to give the 16 bit input on fpga kit on spartan 3E??
in my entity inputs are 16 bit std_logic_vector.and in spartan 3E kit only 8 switches are avaliable for 8 bit input,....so how can i give the input which is greater than 8....
if you use xilinx then in source window keep implementation /synthesis then in process window design utilities click the + mark. and give assign package pins.if you have spartan 3e kit manual there will be pin no for switches. enter the no in window which is opened while clicking yhe assign package pins.
