how to give delay in vhdl
Junior Member level 2
I want to follow this algorithm :
d(n)=output(2n+1)-(1/2)[output(2n)+output(2n+2)]
where ''output'' is an array consisting of 64 values...
after each clock cycle ''d(n)'' gets a definite value based on calculation
so according to this algorithm d(n) must contain 31 values...
but this algorithm should start once all the values are loaded in output...(that means i have to create a delay and then only the above algorithm should start working)
my code is
---main code
Code VHDL - [expand]
8
9
10
11
12
package newtype is
type row_t is array(0 to 63) of integer;
type approx_t is array(0 to 30) of integer;
type matrix_t is array(0 to 7, 0 to 7) of integer;
end newtype;
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
use work.newtype.all;
entity test is
port(input: in matrix_t;
clk: in std_logic;
output : inout row_t;
d : out approx_t);
end test;
architecture arch of test is
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
signal matrix : matrix_t;
signal temp_row : integer;
signal temp_approx : integer;
signal i : unsigned(5 downto 0) := "000000";
signal n : unsigned(4 downto 0) := "00000";
signal count : unsigned(6 downto 0) := "0000000";
signal limit : unsigned (6 downto 0) := "1111111";
signal row, col : unsigned(2 downto 0) := "000";
begin
process(clk)
begin
if rising_edge(clk) then
temp_row <= input(to_integer(row), to_integer(col));
     output(to_integer(i)) <=temp_row;
     col <= col + 1;
    if col = "111" then
      row <= row + 1;
    end if;
     i<=i+1;
count <= count + 1;
    if count >= limit then
temp_approx <= output(2*((to_integer(n)))+1)-(1/2)*(output(2*((to_integer(n))))+output(2*((to_integer(n)))+2));
d(to_integer(n)) <= temp_approx;
n<= n+1;
end if;
end if;
end process;
end arch;
---testbench
8
9
library IEEE;
use IEEE.Std_logic_1164.all;
use IEEE.Numeric_Std.all;
entity test_tb is
end;
architecture bench of test_tb is
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
component test
clk: in std_logic;
d : out approx_t);
end component;
signal input: matrix_t;
signal clk: std_logic;
signal output: row_t;
signal d: approx_t;
constant clock_period: time :=  0.1ns;
signal stop_the_clock: boolean;
begin
uut: test port map ( input => input,
clk => clk ,
output => output);
stimulus: process
begin
input <= ((0,1,2,9,10,5,8,4), (3,5,6,10,2,9,10,5), (9,8,11,2,10,2,9,10), (9,7,1,6,10,2,9,10),(1,4,5,3,6,10,8,9),(14,2,3,5,6,7,8,9),(9,7,1,6,10,2,9,10),(12,4,7,8,9,2,12,0));
wait for 50ns;
stop_the_clock <= true;
wait;
end process;
clocking: process
begin
while not stop_the_clock loop
clk <= '1', '0' after clock_period/2;
wait for clock_period;
end loop;
wait;
end process;
end;
but my ''d'' is showing garbage values
This is what simulators are for - debugging.
Follow the error backwards from the end - does temp_aprrox get reasonable values? does output get reasonable values? Are row and col correct at the correct times?
But on a side note: why is output an inout? if you need to read an output you should really make a temporary internal signal.
Also - why have you set the clock to be 10 GHz?
Reactions: 214
    214
To mention another trivia, factor (1/2) is just zero in integer arithmetic. You probably meaned
output(2*to_integer(n))/2
You should also be aware of your unsigned index counters overflowing and wrapping around, continuing to write to the output and d arrays. Don't oversee easily if this causes problems.
Reactions: 214
    214
yes temp_aprrox, output gets reasonable values .
and yes row and col are correct at the correct times.
only problem is with "d"....
yes I changed the code accordingly but it is still not working
As suggested "Follow the error backwards from the end"
You can trace code execution by cycle, so you should see if d ever gets correct values and if they are possibly overwritten later.
A counter could insert the delay or maybe clock division
