How to get flat broadband LNA design with narrow gain differemce
hari_preetha
Full Member level 2
I have designed LNA from 13 -16 GHz. I would like to get flat broad band LNA from 13-16 GHz of gain variation ± 0.5 dB. I tried lot and couldn't get flat band from 13-16 GHz. What should be done to get flat gain variation of ± 0.5 dB?
Please find attachment of LNA ckt and result
Applying a Series and/or Parallel Feedback may maintain the Flatness by suffering Gp.( Preferred Method )
Or..
Using a Cascode Configuration is very common method to achieve Wide-band Response ( Optimization easier that Cascade Config.)
Or..
Here same ckt is used as ckt I used i in posting #1. They achieved flat top gain over frequency range of 7- 15 GHz (schematic ckt and plot of gain is attached). What should be done for my ckt to achieve gain flat broad band of variation + or - 0.5 dB variation over frequency range of 13 - 16 GHz, which component I should vary for getting flat for desired range. Please advice it.
