mr_evo
Junior Member level 1
Hello!
I'm trying to implement adaptive lattice algorithm in matlab. It has prediction part which require to use previous samples.
For instance line 2 in figure (see attached) operates with instants of n-1, n-2. In order to implement this in matlab I use 'for loop'. But it can operates only with positive indexes. Thus, I need to use loop for n=3:N.
At the same time in these loop some of the variable should be initilized for each instant n>=1 (see point 2 in figure). But my loop starts from n=3. In this case first two samples of the original signal will be missed.
Do you have any idea how can I use all signal samples with this algorithm?
Thank you in advance!
