BackerShu
Member level 3
I am trying to generate a clock signal with random noise, but not using complicated VCO models in Cadence Spectre.
One possible way I think is to use the vsource in analogLib with "prbs" type, and specify the bit file with "...0101..." pattern. So that, I can put the noise for the pattern as provided by the vsource model.
But I don't know how to construct the bit file. Could someone please explain how to do it by brief steps or direct me to some reference?
Or any other simple way to generate such clock with random noise?
Thank you!
Thank you!
