bestvlsi
Junior Member level 1
LC VCO how to design a switch with discharge path for the stored charges
Hi there,
I am designing an LC VCO with switch capacitor bank in 0.18um process. This is being used in a radiation environment where it can face situation where there might be accumulation of charges in the capacitors due to radiation. At the moment I am using the topology as in the figure attached. In the picture attached, the external digital control is applied at the gate of the MOS transistor and the other end of the capacitor is connected to the output terminal of the VCO.
Could the VCO functionality be changed if the stored charge exceeds certain limit ?
Also is there any topology to discharge the stored charge in the off state of the switch ?
Regards
Hi there,
Regards
