how to design a larger N PLL synthesizer.
chmhero
design a intege N synthesizer.
reference clock 50K
bandwidth 5KHz(big cap in chip).
N =1000 above
i set the Icp to 5uA, sb tell me the leakage current is so much, and the leakage curren will generate the spur , how to estimate the spur? how to design the PLL with less spur.
any advice is welcome .
who can help me ? thanks .
the nonideal effects in charge pump produce the spurs, usually harmonious of the compare frequency.the effective means to reduce the spurs is to eliminate or alleviate the nonidealities.
reference clock 50K
N =1000 above
You'd better adjust bandwidth to filter the spur. Perfect charge pump doesn't exists!
N=1000 is very large for CPPLL, and the bandwidth is so small that the VCO's noise contribution is too large. CPPLL is not a good solution for such a synthesizer. DDS may be more useful.
sorry ,the PLL is a clock multiplier. like the ADI 9883 or ICS1523.
both two chip have external component(cap and res). i am looking for a idea to t to avoid the external component .
chmhero:
I am sorry to say it is impossible to avoiding the external component.
Selina
Hi Chmhero,
In the e-book "CMOS PLL Synthesizers: Analysis and Design" chapter 5, you can find the solution for large N PLL.
You can reduce kvco based on good structure,then you can increase Icp and reduce spur.
yes, it's a good idea
i'm working on the same project recently, use a 30K fref to generate 20M output signal for local osc.
