I am not sure that you can do that. Maybe you can try putting a 0 volt voltages source between net1 and net2. Since you have declared net1 and net2 as globals then you should be able to put the voltage source anywhere .
thank u for ur reply.
But actually i wanna set two nets to be same in netlist such that i can run lvs. Since 1 net is defined as global signal in the netlist , then how can i define another one to be same as that one?
Hum... the lvs tool we use actually has the switch to join nets or change name of nets, both of which should work....
If not, we've used a small value metal resistor to short two nodes with different names together. You need to do this in both layout & netlist. This "should" work on globals as well....
