How to convert a circuit from old technology to new technology
tompham
Full Member level 2
usa
Dear all
I have a question how to convert a circuit from old technology to new technology.
Let say I have a bandgap design using 250nm technology and want to design to 180nm. How I can do it:
Do I have to design from beginning using 250nm schematic?. Assume both process bandgap take out 1.2v
Thank you
Short answer: yes.
Long answer: you can write scripts and stuff to do that but not all of the processes follow the same annotation for their elements and methodology of them are not the same as well as their parameters. So it's easy enough to automatize the schematic transfer but you're going to have to run all your simulations and stuff.
Additional answer: Some processes can be scaled down, for example 65nm can be scaled down to 55nm, in that case migration is basically doing nothing.
Additional additional answer: Since after designing the circuit in 0.25um you will have a lot of experience designing these stuff and their relations, you wouldn't have that much of a problem designing a new one. Also you should keep all your testbenches and create generic testbenches and stuff.
