How to convert (-3.3 to 3.3VDC) to (0 to 3VDC) ?? i.e. voltage shifter
yzou_ua
Member level 5
I have a AC voltage to be feedback to ADC of controller. So how can I shift the voltage level to the 0~3.3VDC then?? I tried a two op-amp(LM301) circ. but not working well...
Could anyone help me out? Thx alot!
Simply divide the ac voltage by 2 and couple it via capacitor to VDD/2 = 1.65V of your ADC ,
(or by 3.3/1.5 and couple it via capacitor to VDD/2 = 1.5V) :
  • R3=R4 , if R4 is the input resistance of your ADC, or R3=R4 « input resistance of your ADC
  • R1=R2 « R4
  • C1 ≥ 1/pi*fmin*R4 ; fmin = lower frequency limit of your ac voltage
search for any Energy meter application note, from Ti.com , the front end has an accurate level shifter
If simple is desirable then this is the simplest method which I think anyone can come up with.
Install a resistance inline with the input. Install a resistance to the positive supply.
Best to start with high resistance. Adjust to obtain desired swing at the output.
This method depends on the surrounding circuitry maintaining stable resistance. If not then the voltage can wander outside safe specs. Which would make post #3 a safer method to use.
