easyads
Junior Member level 1
pa output power
I am design a blutooth PA with output power 4dBm. But the output power must be controled from -30dBm to 4dBm.
1. How can power control be realized? Someome says that using an voltage attenuator to attenuate the input rf signal is an good method. How can an attenuator be realized in cmos or bipolar porocess, could you give the schematic?
2. PA output power control can also realized by changing biasing current or voltage.
But this method can not obtain good linearity. How about this method?
Best Regards
Best Regards
