msdarvishi
Full Member level 4
How to constraint Differential clock and reset in PXIe-700 incliuding a KINTEX7 ?
Dear all,
I am using the PXIe-700 Card provided by Sundance including a KINTEX-7 (xc7k410t FFG900) board (more info here). I do not know where are the differential reference clocks location to connect to AXI Memory Mapped to PC Express module in block design? Also, the reset pin location was not mentioned in its User Guide. I always get the following error message in bitstream generation process:
Can anyone help me to solve this issue? Thanks in advance for your care and consideration.
Bests,
Dear all,
[DRC UCIO-1] Unconstrained Logical Port: 2 out of 3 logical ports have no user assigned specific location constraint (LOC). This may cause I/O contention or incompatibility with the board power or connectivity affecting performance, signal integrity or in extreme cases cause damage to the device or the components to which it is connected. To correct this violation, specify all pin locations. This design will fail to generate a bitstream unless all logical ports have a user specified site LOC constraint defined. To allow bitstream creation with unspecified pin locations (not recommended), use this command: set_property SEVERITY {Warning} [get_drc_checks UCIO-1]. NOTE: When using the Vivado Runs infrastructure (e.g. launch_runs Tcl command), add this command to a .tcl file and add that file as a pre-hook for write_bitstream step for the implementation run. Problem ports: refclkp[0], and refclkn[0].
Bests,
