how to connect microcontroller with traic
ragab2010
Junior Member level 1
hi
how to connect microcontllor with traic by transistor(2n2222) because the current of the pin is 25mA and the traic need 50mA to operate to close ac circuit ..
can show me pic to connecting of the transistor with traic
What is the actual application?
Typically a properly selected optoisolator provides better safety and performance without the need of a transistor.
It should be noted any connection to the mains can be hazardous or even deadly to you or anyone in contact with the circuit.
That being said the following document discusses a microcontroller driving a TRIAC with a transistor instead of an optoisolator.
TRIAC & MICROCONTROLLERS: THE EASY CONNECTION
Proceed at your own risk!
BigDog
thanks ...big thanks
my application is lights flashing .for ac light by using Microcontroller. I use (BTA16 600B) triac.
the Problem when the current flow from microcontroller to triac the glow of light of AC is weak. unless when the current large 50mA the glow of light of lamp AC is nice normal
You can control triac using microcontroller like...
Microcontroller ===> MOC3021 ===> BTA16 (triac).
We use this type of configuration in lots of application and it is work fine for long period....
Regards,
Ghanshyam
gvshyam1682@gmail.com - feel free to contact.
