mmc01
Newbie level 5
I use LDR and Opamp automatic light like this image
I want to connect this circuit with LED. So I'm not use Relay but I don't know how to connect LED instead Relay. I measure between pin C of BC549 and Vin it is 0V all the time. I measure pin C and ground it is 5V because Vin 5V to ground. I measure put across R 4.7k it is alway 0.8V and will be 3 V when dark. I measue between pin E of BC549 to ground it alway 3.7V and will be 6.4V when dark. I can't connect with pin E because it will alway bright and very bright when dark. I only want LED On and Off only. How to connect LED to op amp output ?
