general_custard
Hi there, I have a quick query about how to combine results for an antenna that uses multiple ports, with a different phase excitation for each port. You see I've designed an open-ended waveguide antenna fed using balanced probes, which are excited with 1|0° and 1|180° signals, well in CST it's straighforward to excite each using a coaxial feed with a discrete port, and then use the 'results > combine results' function to provide the phase shift for port 2. However, I have experimental results from farfield measurements of the fabricated structure and I'm just wondering if I'm combining the results correctly. I have the gain in dBi and phase of the received signal at certain frequencies and I've been combining the results in the following way:
mag1 = 10^(gain1(dBi)/20)
real1 = mag1 * cos(phase1)
img1 = mag1 * sin(phase1)
mag2 = 10^(gain2(dBi)/20)
real2 = mag1 * cos(phase2+180°)
img2 = mag1 * sin(phase2+180°)
realsum = real1 + real2
imgsum = img1 + img2
magsum = √(realsum^2+imgsum^2)
gainsum(dBi) = 20*log(magsum)
phasesum = argument(realsum + j*imgsum)
I'm not sure if this is the method CST uses to combine results, it's hard to compare as CST doesn't give phase information for the farfield results I'm especially uncertain about whether the logs have a factor of 10 or 20, aside from that it's just a straightforward vector summation I know, could anyone shed any light on this? Thanks!
