How to combine 4 Fm channels in to one common antenna
aneesholv
India ,kerala
Hai
In my common Tranmission infrastructure ( FM radio Transmission unit ) there are 4 FM channels( each have 5 KW power) including my FM station .Here I want to know How can These 4 FM channel combine in to a single stream for broadcast through a common antenna system ? Can You explain the working of these combining system and antenna ?
Regards
Aneesh
I am not an expert I such high powers, but I believe the do this with a 4 filter quadraplexer. The filters are physically big, due to the need for high Q resonator elements.
I guess these kind of power transponders are combiner with Waveguide Combiners.Otherwise standard circuits and Microstrip Structures/Coaxial Elements can not support these power levels.
It's just a guess..
It's just a guess..
Wave guide combiners are HUGE at these frequencies ? 3m X 3M cross section. A better way would to use resonant acceptor/rejector cavities with special lengths of coax between them which if long enough would give a "comb" filter, nulling out multiple channels.
Frank
