first, u must calc the spurious frequency for integer and frac. then u must calc the spuriou gain, every spurs from diff block have diff transfer factor. Finally, simulate it... In fact, we don't calc it usually. we just have good design in charge pump design, such as mismatch, leakage, timing. You must consider the power/gnd line coupling, ESD coupling and sub leakage, and the spur level is really not easy to pre-calc, but you can get the approximation by smart way.
