vhha
Newbie level 1
Hi there,
I am successfully using the attached ECG circuit to get ECG signal.
The problem is that this circuit needs two separate 9V DC batteries - one for the amplifier circuit & other for the isolation circuit (which has an optocoupler).
This safety feature is great when one is physically connected to a PC using a USB cable, etc.
In my case, I want to build a micro-controller application using this amplifier. As such, I want to supply the micro-controller and the amplifier with same single battery source using voltage regulators.
However, I am unable to use single battery for this amplifier. Because as soon as I start supplying its 2 circuits by the same battery using DC-DC voltage regulators, I lose the ECG signal.
I wan wondering could I just by-pass the optocoupler and get rid of the 2nd 9V battery? Is it as simple as connecting the 4 pins from the amplifier side to the corresponding 4 pins on the optocoupler side (without the optocoupler)? Also, then I could just leave the 9V supply pins disconnected?
Any help/ideas would be greatly appreciated!
Regards,
Vhha
Regards,
Vhha
