Narendra1190
Member level 2
hii frds..
need your help.working on 89s52 project.there are already SIX 7-seg dislplay. i want to add one more 7-segment display controlled by an interrupt.when i m doing it is affecting switching of other six display..how can i do multiplexing with two differnt pattern such that one numerical pattern for six 7-seg. and the other symbolic pattern for seventh seg. display controlling with interrupt.
how shld i add code?
the working code of six 7 seg. display is below.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 void seven_seg_disp (void) interrupt 1 //timer 0 isr { EA = 0; TR0 = 0; if(i == 1) { P0_1 = 1;P0_2 = 1;P0_3 = 1; P0_4 = 1;P0_5 = 1;//P0 = 0xFE; //1add //1111 1110 P2 = lcddata[Li[0]]; //0 P0_0 = 0; i++; } else if(i == 2) { P0_0 = 1;P0_2 = 1;P0_3 = 1; P0_4 = 1;P0_5 = 1;//P0 = 0xFD; //2add //1111 1101 P2 = lcddata[Li[1]]; //1 P0_1 = 0; i++; } else if(i == 3) { P0_0 = 1;P0_1 = 1;P0_3 = 1; P0_4 = 1;P0_5 = 1;//P0 = 0xFB; //3add //1111 1011 P2 = lcddata[Li[2]]; //2 P0_2 = 0; i++; } else if(i == 4) { P0_0 = 1;P0_1 = 1;P0_2 = 1; P0_4 = 1;P0_5 = 1;//P0 = 0xF7; //4add //1111 0111 P2 = lcddata[Li[3]]; //3 P0_3 = 0; i++; } else if(i == 5) { P0_0 = 1;P0_1 = 1;P0_2 = 1;P0_3 = 1; P0_5 = 1;//P0 = 0xEF; //5add //1110 1111 P2 = lcddata[Li[4]]; //4 P0_4 = 0; i++; } else if(i == 6) { P0_0 = 1;P0_1 = 1;P0_2 = 1;P0_3 = 1; P0_4 = 1;//P0 = 0xDF; //6add // 1101 1111 P2 = lcddata[Li[5]]; //5 P0_5 = 0; i = 1; } } TH0 = 0xFC; TL0 = 0xEC;// TL0 = 0xBE; TR0 = 1; EA = 1; } void appetizers (void) { P1 = 0x00; //to disable stapper motor P0 = 0xFF; TMOD = 0x11; //timer 0 and timer 1 both used EA = 1; ET0 = 1; EX0 = 1; //enables external int0 IT0 = 1; //ex interrupt0 in falling edge mode TH0 = 0xFC; TL0 = 0xEC;//TL0 = 0xBE; TR0 = 1; //timer0 is used for refreshing 7seg array. }
