How make a PIC based Voltmeter for 24 volt reg. Power Suply?
terka
16f84 voltmeter
Tha is.....someone can helpme please??
I want make a PIC based voltmeter using 16F84 /ADC0832 or 16F877A, but i dont know home make the circuit/schematic for this...
I have tipical power suply with a LM317T...
Thankz
make voltmeter
mm
I found a PIC Power supply in elektor magazine, link is this forum...aply search...jejejeje
it´s made with transistor...
Bye
voltmeter using pic
How about precise of you meter.
If you test voltage ranger beyond 256 grade,you should use two or three channel amplifer to generate 2/3 gain voltage,then input to ad0832
16f84 for voltmeter
If you use a 16F87x , you don't need to se an external ADC, just aply the 24V dc to a resistor divider, for instance use 1k and 4k in series, you'll get 5V at PIC ADC input, from a 25V input, the rest is just code.
bf245 16f84 voltmeter
Hello
Thank for you reply
I have 24v trafo...in DC there is 30 volt aprox....in the out of regulated part apear 29 volt....I want to make a volt/current meter with 16F84 and ADC0832 (2 channels) using a LCD module....
8 bit definition is possible...
I wait uoy reply
Thank
Re: 16f84 voltmeter
Hai Terka,
Try this project........nice and coooooooooool
waiting for your replay...............
  • DVM.rar
