How does a class B amplifier reduces even order harmonics
egemini
Full Member level 2
GOC
Please explain with equations
Re: How does a class B amplifier reduces even order harmonic
Hi
Actually it does not, the second harmonic is very much present in class B.
However it is way easier if you read this in the exellent book by Cripps:
"RF Power Amplifier for Wireless Communication" section 3
I think you can find the book in Ebook section.
Regards
Could it be that you mean symmetrical class B (or push-pull) amplifier?
yes really I meant class B pushpull amplifier
Well, then the answer is very simple and general: Assume that the output waveform of the amplifier has a considerable degree of distortion, but is exactly symmetric, it will have no even harmonics at all. This can be seen from fourier series respectively fourier transformation. See the fourier series of a square or trapezoid waveform as an example.
    egemini
Push-pull Class B
    egemini
vfone said:
Push-pull Class B
Hi vfone,I dont understand why ID2 is negative (-ID2)?and why ID=ID1-ID2? Thank you!
