How do you get this waveform?
JiL0
calculator harmonicfreq cadence
Does anyone knows how to simulate a circuit to determine the harmonics of the circuit? What simulation should i conduct ( AC, DC, PSS...etc ) in order to obtain a waveform as shown in the picture?
I'm using cadence and i'm trying to simulate the harmonics of a filter, ADC and opamp. Really hope someone can help.
cadence harmonicfreq
If you simulate ADC, you will input sin or two-tone sin signal. Then, you will FFT the simulation result. OK, you will use matlab to obtain the waveform.
cadence harmonicfreq function
In cadence wave form viewer also u can get this waveform by plotting the FFT or DFT for a perticular number of cycles and record points for the sinewave input.
you can get the matlab toolbox on this web site **broken link removed**
What i did was, i perform a transient analysis with an input signal of 10kHz. Then i plot of the output on the waveform window. Then i chose calculator. I selected the output wave into the calculator's buffer. Then i choose DFT under the special function. In the DFT option form, i key in from 10k to 1M , number of sample 64, window type rectangular, coherant gain= none. Then i click plot.
What i get is a graph with a vertical line at 0 and zero elsewhere.
You can use FFT function in calculator or maybe harmonicfreq.
I tried using harmonicfreq and also harmonic. Wat i did was i did a transient analysis. The i add the output wavefrom into the calculator buffer. Then i chose special function harmonicfreq/harmonic. Under harmonic number, I chose any number (1-10) and i click plot. But the CIW says the wave is not a waveform object that can be displayed and will be turned OFF automatically. :(
Sorry, i dont have a matlab programme. Is it possible to do it on cadence?
Thanks everyone. I think i got it. :) Must change the yaxis to log scale.
Thanks for all your tips.
Update: But it is only for DFT. Still cant get the continuous harmonics waveform :(
the running time and frequency of sin is strict needde, u can refer to some paper about the FFT analysis
Sorry, dont really get wat you mean. Can give a simple example?
