ahgu
Full Member level 3
I have a signal in the range of 0.5v-2.7v, need to feed that to an ADC with a range of 0-2.5. What is a good easy low-noise precise way to lower the signal by
0.3V?
If I use a OPAM subtraction circuit, generate the 0.3v using a resistor divider, I was afraid the matching resistor error, and also supply noise from the dividor.
It is single supply opamp.
thanks
Ahgu
0.3V?
thanks
Ahgu
