matrixofdynamism
Advanced Member level 2
We often use the set_location_assingment tcl command when assigning ports to pins on the FPGA in Quartus II. I cannot find a way in tcl to get a collection of all pins that have been assigned to ports of top level entity. The following is desired by using this collection:
1) Look at each value in the collection, if it matches a certain criteria then remove the location assignment
1) Look at each value in the collection, if it matches a certain criteria then reassign the location assignment to different pin
2) print all the location assignments into a file that can be opened in excel e.g csv file
I would expect it to be get_all_location_assignments. But it does not exist :shock:
