How can we use Altium for RF PCB layout? For example a BIAS T. Anyone please help.
Thanveer
Newbie level 6
Hope attached pdf helps
  • lwa0135.zip
You have to first make the layer active in which you want to do measurement.
Than it will automatically snap to point-point.
Suppose you want to measure dimension of two lines in Top Overlay than first make top overlay active than you will get point to point measurement for those two lines.
Thanks hips...Actually I was doing it. It just that we have to click "Camtastic" on bottom if you are dealing with a Cam file in order to see the numeric value.
Now again will be helpful, how can I add text on a Camtastic layout. Thank you again.
I have not worked on Camtastic so cant help you on that.
But why dont you add text in PCB itself as Camtastic is only for gerber viewing.
The good think with these windows applications is, they are almost self-explanatory. Did you ever try "Place - Text" from the Camtastic menu?
Thanks hips guyz,
One more thing, I am importing dxf file from DWGeditor to Altium using CAMtastic editor, it seems like it’s not importing the text and also the Hatch. Is there anything I can do while importing which can fix this problem.
Your help will be much appreciated.
Thanks again.
Thanks hips,
One more thing, I am importing dxf file from DWGeditor to Altium using CAMtastic editor, it seems like it’s not importing the text and also the Hatch. Is there anything I can do while importing which can fix this problem. pLEASE hELP
Thanks again.
