How can i realize that the FPGAs configuration is completed?
Mehdi1357
the Earth
Hi my friends
I have designed a hardwrae based on Spartan-3A generation, and i use VHDL to programming.
Please tell me how i can realize that the FPGA's configuration is completed an the FPGA is ready to use. i want to use this feature to initialize my internal register by desired values.
Are there any solutions to detect it by hardware or software?
Can i connect the FPGA's PROG_B pin to one of its I/O pins to detect it?
thank you for your attention.
Re: How can i realize that the FPGAs configuration is comple
For XC5202, Spartan, Spartan XL that I've used in the past I'm using to look the DONE pin, when the FPGA is succesfully configured this pin goes to logic high.
Some other info can be found here
Hope it help.
Bye
Pow
    Mehdi1357
I appreciate you.
please tell me can i connect FPGA's DONE pin to another its I/O pin to detect end of cofiguration in vhdl code and use this I/O like a Reset input?
are there any better solutions?
I think you can but if I were you I would at least add some delay for the reset signal.
Yes of course
I will include a RC network on DONE pin.
See attachment.
[/img]
Mehdi1357 said:
I appreciate you.
Before DONE going high logic inside the FPGA is not working because the programming stage isn't completed, after DONE will go high the FPGA start to work, is better check the DONE pin outside the FPGA and when this is high send, after some time, a reset signal to the selected FPGA input. For example you can use a reset ic (remember also to put a pull-up resistor, 10kOhm, from the DONE pin and the positive supply), or use a simple passive RC network to delay this signal but may be you can see another very important issue, FPGA input have a maximum value for the signal rise time applied to the IO pins for this reason a reset is the best safe solution from my point of view.
Bye
Pow
Feeding back the DONE signal to an FPGA input to my opinion should be completely unnecessary, cause the code can achieve a defined state after configuration without an external signal. Or isn't this the case with Xilinx FPGA?
I don't know there is a software solution to initialize my registers by desired values after configuration process (without RESET input). but i know initial values that loaded in to defined SIGNALs or VARIABLEs when we are defining a SIGNAL or VARIABLE won't be synthesizable in ISE software.they are implemented during simulation process.
do you have a better idea?
