how can I open .dxf file in cadence AWR
mohamis288
Full Member level 3
Hello,
I have downloaded a .rar file from NXP company. It contains two .dxf file. But I do not know why it gives a couple of warning. I have uploaded the zip file here in the attachment and I will show you the picture of the warning.
  • MRF300AN-230-MHz-Test-Fixture.zip
What are you trying to achieve?
Don't think that you can import a PCB drawing to an EM simulator without specifically extracting the intended data. In case of doubt, it should be edited in a dxf tool before.
In AWR right click on EM Structure/Import DXF..., point to the DXF file you want to use, and then Select a Simulator (which you want and is available).
