[SOLVED] How can i interface 7 seg with atmega8 without using PORTD?
hardik.patel
Member level 5
Hi all,
i want to interface 7 seg display(max. 4 piece using multiplexed method) using atmega8.
If i use PORTD as data port n any other 4 pin as control then its simple.
But in my application i also need to receive serial data on serial port(RXD pin--PD0) so i cant use complete PORTD as data, so by force i need to do something like divide the data pins on 2 different ports n control pins on other port.
So does its possible ?? how?
(i already done RTC,EEPROM,UART, n basic I/O operations in this application, so no issue regarding basic understanding.)
hi,
If the displays are only 7 segment you only need 7, PORTD pins for the segments and another PORT's 4 pins for digit select.
This will leave PORTD.0 free for the serial RXD.
Example image;
ULN drivers were used as they were very large LED's
E
My problem is I have to free PORTD due to RXD.
Or atleast RXD pin,
But your image is not the solution.
Even I don't want to use ".dot"
So now can I do free PORTD?
See attached image for the circuit. See below code.
char mask[] = {...};
PORTD = (PORTD & 0x03) | (mask[digit[x]] << 2);
PORTB = (PORTB & 0xFE) | ((mask[digit[x]] & 0x40) >> 6)
Or at least RXD pin,
You say you want to use only PD0 as the RXD pin.?? this leaves RD1 thru RD7 ie: 7 pins free for the 7 segments.
So what am I missing.??
Eric
@esp1
PD0 is RxD and PD1 is TxD. As he is using UART in his project he cannot use those two pins.
The thread is missing a clear question. ATmega8 has plenty of IO-pins beside PD0 and PD1. Any combination of it can be basically used to drive a 7 segment display, at worst case without specific order if you accept a certain code overhead.
@esp1
hi pic,
That makes sense if he wants to use both TXD and RXD pins.
Thanks
Eric
hi pic,
Thanks
Eric
I only want to use RXD.
Nothing I am transmitting back.
So I want to use
PD1-segA
PD7-segG.
N I am giving data as PORTD=0x3F;
So both task I want to achieve on same port 7seg as o/p n RXD as I/p.
I don't know whether you can use PD1 (TxD pin) as IO when you have configured to use UART. I have never done something like that.
I had solved this query by defining each segments like..
#define segA PORTB,0
So I can now access single pin rather than access complete port.
