timedate
Member level 5
Hi, all
I want design a Return to Zero optical link with variable duty cycle.
I started it from 50% duty cycle.
Following is my block diagram. Basically, I use a and gate to generate 50% duty cycle Return to Zero(RZ) signal
and use D flip flop to recover the signal to Non-Return-Zero.
So my question is , are there some off-the-shelf RZ/NRZ converter ? (I prefer not to use this D flip flop)
I can find the NRZ/RZ converter, for example, HMC706LC3C or **broken link removed**.
I can also find a discontinued RZ/NRZ converter, like SHF 315 P...
or any options on this optical link ,
or some design guide for Return to Zero optical link ?
thanks all .
thanks all .
