how can i covert 5v to 2.5v ?
weny0247
Junior Member level 1
China
I need covert 5v to 3v !how many way to implent it!?help me !thangks
well converting 5v to a voltage lower than that is easy using a regulators... you can try one of the regulator circuits like series regulator,shunt regulator etc.....
If you don't need much current, say, less than 15mA (LM358), you can use a 2-resistor voltage divider followed by an opamp voltage follower, 2.5V zener voltage reference etc. etc. ..
For higher currents look for low dropout voltage regulators ..
Here are some examples:
Regards,
IanP
the answer should be determined by your purpose. if you need only a voltage, you can get it through resistors. if you need voltage and current, you need a regulator.
i agree with him. in my case, i have designed a voltage reference using a bandgap circuit instead of a regulator. it also serve the purpose. i need to lower the voltage and at the same time it have to be temperature invariant.
I think you have to describe your goal, is your 5v voltage stable, and is the 2.5v you needed is independent with power supply, temparature and process?
u can use buck DC-DC or LDO
Simplest way is to use the inverter. i.e. Select 5V NMOS and PMOS devices. Supply voltage for Inverter is 5V. Input swinging from 0 to 2.5V. At the output of Inverter .... u will get low swing ... so, add two more inverters of 2.5V supply for full swing ....
-Vishwa
It depends on your requirement.
If you need a low noise converter, LDO is good.
If efficient or heat generate is important, DC/DC is good.
If just need a voltage conversion, just us resistors.
DEPENDS UPON UR APPLICATION A SIMPLE VOLTAGE DIVIDER NETWORK WITH RESISTORS WILL DO THE JOB.....ELSE USE A 2.5V ZENER DIODE....
Added after 2 minutes:
OR VARIABLE REGULATOR LM 317
distribution
Added after 18 seconds:
English
Thangks you all! ic supply is 5v !but ic working voltage is 2.5v ! ic current is 50-100mA,!what i think is choose dc-dc or ldo! if iselect dc-dc !I dont hope to use L or lager C !
use regulator or resistor devision.
I can not use inductance !so I can not use buck! only sue LDO
Hi Weny0247,
I checked a number of LM317's in the usual circuit with two 220 Ω resistors
and they all worked, but only just. If I lowered the supply voltage to 4,5v
most of them lost it completely, and that was without any load. I also checked
a LT1085CT and this one kept working down to 3,6 v, also witout any load.
Take a look at the datasheet:https://www.linear.com/pc/productDetail.do?navId=H0,C1,C1003,C1040,C1055,P1283
I think that you will agree that this regulator is a suitable candidate for your
application. A 3 A regulator is a lot of overkill but it doesn't matter if you hit
a mosquito with a newspaper or with a baseball bat, main thing is that you've
got it ! 8) Replace the 365 Ω trimpot in the schematic with a 121 Ω resistor and you've got the 2,5 v you need.
on1aag.
try to use switch cap.
