Horn antenna simulated using HFSS request
salma
Junior Member level 2
Hi all
Is there anybody that simulated a horn antenna using HFSS??
I am grateful if he(or she) upload it for me.
Best regards
hi i need simulation on dual rigided horn antenna on hfss can somebody help me im stucked
You need a simulation file of Dual ridged horn antenna? where are you stuck, post your file and i will try my best to help you out.
Elchiquito
actualy i made normal horn antenna but i dont know how to add ridges into it . do you have some simulation file on hfss on dual rigided antenna for UWB applications? i really need it
No unfortunately i don't have a file. But refer to this paper for the equation of ridges and that should help you out. Let me know if u have a hard time drawing the ridges.
Elchiquito
  • Quadridge horn.pdf
can u implement this paper u have uploaded in HFSS i will be gratefull kz iam not getting the way to implement it if i get the simulation i will learn it fast its a request
Brother
how do you know that you can't implement the design yourself without even trying, are you expecting people to spoon feed you. and how do you expect to learn when someone does it for you? does it make any sense.
sorry brother i can help you design it if you get stuck but cant do everything for you
Elchiquito
i implemented a horn antenna but iam not getting the logic to add ridges into it . i achived my required results without ridges i tried alot but iam not getin the way how to make the geometry that the case bro
---------- Post added at 23:07 ---------- Previous post was at 23:05 ----------
if you have any tutorial how to make dual rigided horn antenna for UWB applications or simple how to make dual rigided horn antenna kindly upload it
---------- Post added at 23:11 ---------- Previous post was at 23:07 ----------
did your problem solved
Did my problem solve? what do u mean by my problem. am i the one seeking help for my problem here?. All the best ! Have fun
Elchiquito
Dear Elchiquito you took me wrong . i was answering the first top most post in which somebody was asking about horn antenna hfss file . that message was not for you bro ... misunderstanding
Here is the file bro
  • horn.rar
Brother here is the file. please find it appended. i have not simulated it, simulate the structure and let me know
Elchiquito
  • Quad_ridged.rar
sorry i have attached the wrong file. i will upload the correct file in few minutes time. wait until then
Elchiquito
ok bro iam waitng
Here's the file. simulate it and let me know.i have seen the simulation for vertical feed, then i have added dual feed, results are satisfactory. drawing the ridges is time consuming process and takes a good understanding of geometry
Elchiquito
  • Quad_ridged.rar
Reactions: ferdows
    ferdows
    V
bro it is giving error in hfss it is not opening
---------- Post added at 23:40 ---------- Previous post was at 23:39 ----------
the previous file that u sent by mistake was opening but it is not
Well the file is simulated in HFSS13 and HFSS is not backward compatible. if you are using a lower version of HFSS you wont be able to open it
Elchiquito
ok Do you have the setup of HFSS 13?
---------- Post added at 23:45 ---------- Previous post was at 23:44 ----------
is there is any way to make it open?
HFSS13 is a copyrighted software, do you understand the consequences of asking for setup files here on the forum
elchiquito
