usually, use the same input power, high gain or low gain is just your controll mode. it is nothing to do with the input power.
if you simulation your circuit, input power chose -55dbm from -45dbm at 50 ohms input impedence.
Depends on your application. I have worked with manpack sets (walkie- talkies) that can handle their aerials touching with TX pwr = 12W and the receiver switched to the same channel!!!
Frank
