pinoismo
Newbie level 3
I want to design an op amp with the following specifications:
* Allowed transistors are the 3904 (npn BJT), 3906 (pnp BJT), 2N3819 (n-channel JFET).
* The input is a 1 mV amplitude source at 1.0 kHz riding on a DC value between -1.0V and +1.0V. The source has a 4 kΩ source resistance.
* The primary goal is to provide a 2 V amplitude sinusoidal output across a 100 Ω load with an average value as close to 0.0V as possible.
* No capacitors are allowed.
* Standard resistor values must be used.
* Supply voltage is to be provided by no more than 2(two) 9V batteries.
