hfss microstrip patch antenna at 5.83GHz coaxial feed elliptical patch
hemantbansal22
Newbie level 3
I have an assignment to design microstrip patch antenna at 5.83ghz with elliptical patch please help how to design .
I found the document attached online on how to design a rectangular microstrip patch antenna using a coaxial feed. Just go through the design procedure and modify it for elliptical patch. And go through some books of microstrip antenna design, you might find exact design procedure on how to determine the location of the feed point for the co-axial feed.
Which simulation software are you using?
  • Coaxial_Microstrip_Patch_Antenna.pdf
@ sv1437: Could you send me the full book. This chapter that you sent is very useful. Thank you very much!
