CVNickesh
In HFSS, I'm trying to create a simple cylindrical parallel plate capacitor, but I'm having issues assigning wave ports.
I'm using a driven terminal solution type in HFSS V17.1
I've created a dielectric of quartz as a cylinder with radius 25mm, depth 20mm.
I've created two sheets, each with radius 17mm (half the area of the dielectric face) and positioned them on the top and bottom faces of the dielectric.
I want to assign these sheets as made of copper, assign one as the wave port and the other to ground, can someone tell me how to do this, as I keep getting port refinement errors?
The aim is to have a simple cylindrical shaped parallel plate capacitor with copper ports (terminals?), and drive a 1V, 2.45GHz AC voltage between them, and observe the field vectors inside the dielectric.
