HFSS Cavity Patch Antenna
TXRX
Full Member level 2
See attched, I want to add cavity at the bottom of the patch antenna at a high of 1mm to increase the bandwidth.
The circle plane is the ground plane, How can i define the cavity ? PEC ? Air inside ? Is the definition the same like circle ground plane ?
Thanks
