madnaveen
Newbie level 6
off grid netparameter
I am using Protel DXP and after i create my schematic and compile the project, i get the following warnings:
(1) off grid pin xxx at yyy,zzz where xxx is the pin number of a component and yyy,zzz is physical location of the pin on the sheet. I have a component with 8 pins and i get this error for 4 pins only.
(2) off grid netparameter at yyy,zzz where yyy,zzz is a location.
(3) Nets wire ABC has multiple names. I know what this means but i am working on a multi sheet design and there is an instance where nets with different names interface with a microcontroller. is this is majaor issue? or can i ignore and work as my netlist shows the pins i want to be connected as connected.
thanks
Naveen
thanks
Naveen
