floppy32
Member level 1
I need to use this relay module to switch ON/OFF this SMPS either from at AC input or its DC output.
The SMPS is rated as 12VDC 10A and in my case it will source 5A to 6A to a module.
As you see the relay module uses this relay. An has already flyback diodes and also has something looks like MOVs.
The thing is I was planning to use the relay module for AC side(line) of the SMPS, but I noticed that the SMPS datasheet shows the following:
INRUSH CURRENT: 60A
And the relay I guess cannot handle this inrush current(?). And the relay contacts might weld(?)
So then I thought to use the relay module for the DC side of the SMPS. In this case it is rated as 5A at 30VDC.
In my case it needs to handle a current between 5A to 6A at 12VDC.
So I am stuck at this point and for some reason difficult to buy another relay.
Which option is safer or what could be done to remedy either AC or DC cases?
For the AC case: I heard about NTC series but I don't know how to size it or would that work.
For the DC case: I might exceed 5A a bit but at 12VDC. So I'm not sure would that be fine or require any heatsink ect.
I would be very glad with any suggestions/workarounds.
Thank you
INRUSH CURRENT: 60A
Thank you
