PeterUK2009
Member level 4
Hi guy I need some help here!
I am trying to do something that suppose to be really simple but its taking me some time!
The goal is to produce a HDL code which send a letter to the PC by the serial port UART.
the communication is
19200 b. rate
8 bits data
1 bit start
1 bit stop
no party
no error
so 1 bit start by 8 bits of data and the 1 bit stop!
the stop tick rate at 16
I am try to send the letter A which is 41 hex which is 00100001 binary and I am getting in the PC the symbol "." which is 2e hex and "00101110" binary
The hardware is a Spartan 3 board at 50 M clock from xilinx
I would like to add that I have run the manufacture test which write spartan dev 3 kit ( or something like that) and it works fine. Therefore, the board, the max232, the cable, the PC, and the serial application is working fine!
I am attaching a link there my vhdl code and also the ucf code.
Thanks for reading looking forward to hear from you!
19200 b. rate
8 bits data
1 bit start
1 bit stop
no party
no error
entity uart_sendOnly is
generic(
N: integer := 8; -- number of bits
M: integer := 163; -- mod-M
DBIT: integer:=8; -- # data bits
SB_TICK: integer:=16 -- #
port(
clk, reset: in std_logic;
tx_start: in std_logic;
-- s_tick: in std_logic;
din: in std_logic_vector(7 downto 0):= "01000001";
tx_done_tick: out std_logic;
tx: out std_logic
end uart_sendOnly;
architecture Behavioral of uart_sendOnly is
--mod m counter
signal tick: std_logic;
signal r_reg: unsigned(N-1 downto 0);
signal r_next: unsigned(N-1 downto 0);
signal s_delay: std_logic_vector(15 downto 0) := "0000000000000000";
type state_type is (idle, start, data, stop, delay_t);
signal state_reg, state_next: state_type;
signal s_reg, s_next: unsigned(3 downto 0);
signal n_reg, n_next: unsigned(2 downto 0);
signal b_reg : std_logic_vector(7 downto 0) := "01000001";--A --have the word to be sent
signal b_next: std_logic_vector(7 downto 0);
signal tx_reg, tx_next: std_logic;
begin
-- register for mod m
process(clk,reset)
begin
if (reset='1') then
r_reg <= (others=>'0');
elsif (clk'event and clk='1') then
r_reg <= r_next;
end if;
end process;
-- next-state logic
r_next <= (others=>'0') when r_reg=(M-1) else
r_reg + 1;
-- output logic
-- q <= std_logic_vector(r_reg);
tick <= '1' when r_reg=(M-1) else '0';
process(tick)
begin
if (tick = '1') then
-- s_delay <= s_dealy +1;
end if;
end process;
------------------finish mod m
-- FSMD state & data registers
process(clk,reset)
begin
if reset='1' then
state_reg <= idle;
s_reg <= (others=>'0');
n_reg <= (others=>'0');
b_reg <= (others=>'0');
tx_reg <= '1';
state_reg <= state_next;
s_reg <= s_next;
n_reg <= n_next;
b_reg <= b_next;
tx_reg <= tx_next;
end if;
end process;
-- next-state logic & data path functional units/routing
process(state_reg,s_reg,n_reg,b_reg,tick,
tx_reg,tx_start,din)
begin
state_next <= state_reg;
s_next <= s_reg;
n_next <= n_reg;
b_next <= b_reg;
tx_next <= tx_reg ;
tx_done_tick <= '0';
case state_reg is
when idle =>
tx_next <= '1';
if tx_start='1' then
state_next <= start;
s_next <= (others=>'0');
b_next <= din;
end if;
when start =>
tx_next <= '0';
-- if (s_tick = '1') then
if s_reg=15 then
state_next <= data;
n_next <= (others=>'0');
else
s_next <= s_reg + 1;
end if;
end if;
when data =>
tx_next <= b_reg(0);
if s_reg=15 then
b_next <= '0' & b_reg(7 downto 1) ;
if n_reg=(DBIT-1) then
state_next <= stop ;
else
n_next <= n_reg + 1;
end if;
else
end if;
end if;
when stop =>
tx_next <= '1';
if s_reg=(SB_TICK-1) then
state_next <= idle;
tx_done_tick <= '1';
else
end if;
end if;
when delay_t =>
tx_next <= '1';
if (s_delay = "1111111111111111") then
state_next <= idle;
else
state_next <= delay_t;
end if;
end case;
end process;
tx <= tx_reg;
end Behavioral;
NET "clk" TNM_NET = "clk";
TIMESPEC "TS_clk" = PERIOD "clk" 20 ns HIGH 50 %;
Net "tx" LOC="R13";
NET "clk" LOC = "T9" ;
NET "reset" LOC = "L14";
NET "tx_done_tick" LOC = "K12"; #led 0
