help: the delay of inverter driver !
gdhp
HI ALL
I am designing a inverter driver to drive a 20-50pf capcitance. i use the
cascade of inverter structure (each is two times than the last one). But the delay
is too large to damage the timing.
So is there other method to do this things?
thanks!
Added after 1 hours 16 minutes:
no reply??
Hi
The counter question is how much delay you want to achive
you should stop the invertor chain when it rise/fall time is comparable to the delay of the inverot chain(say equal, or half )
This may take few nano seconds, based on your technology
Added after 3 minutes:
one more thing i forgot to mention
in case you have a very long invertor chain, dont allow first few stage to saturate, this will buy you some time ,
this is conventional high speed io design strategy
regards
can you get more details,
what voltage, current you are planning to get of it?
