help required to generate smooth pwm sine wave with PIC16F73
Mithun_K_Das
Advanced Member level 3
Dhaka, Bangladesh, Bangladesh
I was designing a sine wave inverter based on smps. other blocks are on, now I need to generate a pure sine wave output with pwm signal. I'm using PIC16F73. Can anyone help me in calculation to get 50Hz sine wave??? And also the filter designing part needs help.
my program is:
float teta;
unsigned char sample[15];
int i=0;
void main()
TRISC = 0x00;
PORTC = 0x00;
PWM1_Start();
PWM2_Start();
PWM1_Set_Duty(50000);
PWM2_Set_Duty(50000);
while(1)
for (i=0; i<15; i++)
teta = ( (float) i / 15 ) * 3.14159;
sample = (int) (255 * sin ( teta ));
PWM1_Set_Duty(sample);
PWM2_Set_Duty(sample);
Could you please post your result up to now?
Hello Mr. Mithun, To generate pure sine with 16F73 you must need a lookup table using calculated sine point. Because 16F series doesn't have enough speed to calculate Multiplication
Try this lookup table : 0,25,50,74,98,120,142,162,180,197,212,_
225,235,244,250,254,255,254,250,244,235,_
225,212,197,180,162,142,120,98,74,50,25
Periodically call them with timer interrupt for 180 degree of sine wave using ccp1 , and swap with other 180 by ccp2
Reactions: Mithun_K_Das
    Mithun_K_Das
    V
