sunjiao3
Member level 5
Hi, friends. I am doubting on the theoretical background of RSSI. There is majorly 2 may to get the logrithmic function for RSSI. First is the piece-wise approximation, used in cascaded amplifiers. Second, which I am not so sure yet, is dependent on the direct power detector which is composed of differential pairs. However, I've found no detailed theoretical reference on the mechanism of these 2 solution. For example, why piece-wise approximation is used? Is it some kind of forula like the Taylor function: ln(1+x)=1+x+.... ?
So, could any one of you please enlight me on this issuse? Or, are there any documents that talk on the methanism on the RSSI? Thank you all in advance.
