Jenifer_gao
Member level 1
Hello Everyone:
I am trying to use a memory cell called switched current memory cell, which is using a switched current technology. It is a cascode cell shown in my attachment. The function of this circuit is as follows:
1. When Φ1 is active and Φ2 is de-active, a total current of J + Iin will flow through M1, the gate of the M1 will be charged corresponding to the total current.
2. When Φ2 is de-active and Φ2 is active. Because the voltage of gate M1 will not change, and as a result the M1 will draw the same current as the phase 1, that means: io = -Iin.
Theoretically, it makes a sense, but when I do the simulation, I don't know how I can observe the output current. I think node output should hook to some where, but i don't know how to do it. If anybody can give me some suggestions, or anybody can give me an example of your design and the simulation file. Thanks very much
