aiko89
module music(
input wire nrst, //reset signal
input wire clk, //source clock 5Mhz
output reg [3:0]note, //index of musical note currently being played
output wire speak //sound enable
//enable sound if current note is not zero index
assign speak = (note !=0);
//one musical step clock counters
reg [20:0]counter;
reg one_step;
reg [4:0]music_time;
//define length of musical step
always @(posedge clk)
begin
if(counter==5000000/4)
begin counter <= 0; one_step <= 1'b1; end
else
begin counter <= counter + 1'b1; one_step <= 1'b0; end
end
//musical time register
always @(posedge clk or negedge nrst)
begin
if(nrst==1'b0)
begin
//reset
music_time <= 0;
note <= 0;
end
else
begin
//play music here, move musical step forward every music time step
if(one_step)
begin
case(music_time)
0: begin note <=3; music_time <= music_time+1'b1; end
1: begin note <=6; music_time <= music_time+1'b1; end
2: begin note <=10; music_time <= music_time+1'b1; end
3: begin note <=6; music_time <= music_time+1'b1; end
4: begin note <=8; music_time <= music_time+1'b1; end
5: begin note <=8; music_time <= music_time+1'b1; end
6: begin note <=6; music_time <= music_time+1'b1; end
7: begin note <=5; music_time <= music_time+1'b1; end
8: begin note <=10; music_time <= music_time+1'b1; end
9: begin note <=10; music_time <= music_time+1'b1; end
10:begin note <=8; music_time <= music_time+1'b1; end
11:begin note <=8; music_time <= music_time+1'b1; end
12:begin note <=3; music_time <= music_time+1'b1; end
13:begin note <=3; music_time <= music_time+1'b1; end
14:begin note <=3; music_time <= music_time+1'b1; end
15:begin note <=3; music_time <= music_time+1'b1; end
default:
//end of music
begin note <= 0; music_time <= music_time; end
endcase
end
end
end
endmodule
//NOTE FREQUENCY SYNTEZATOR
module note_synt(
input wire [3:0]note, //ID of note
//output freq grid
//basic freq is note A = 440Hz
//every next note differs by 2^(-1/12)
//C 523,2511306 Hz
//C# 554,3652620 Hz
//D 587,3295358 Hz
//D# 622,2539674 Hz
//E 659,2551138 Hz
//F 698,4564629 Hz
//F# 739,9888454 Hz
//G 783,9908720 Hz
//G# 830,6093952 Hz
//A 880 Hz
//A# 932,327523 Hz
//H 987,7666025 Hz
//C 1046,502261 Hz
output reg note_clock, //generated note clock
output reg [7:0]note_leds //blink LEDs
//divide coeff
reg [13:0]factor;
//select divide coefficient according to current note being played
always @*
begin
case(note)
1: begin factor = 9560; note_leds = 8'b00000001; end //C
2: begin factor = 9025; note_leds = 8'b00000011; end //C#
3: begin factor = 8518; note_leds = 8'b00000010; end //D
4: begin factor = 8039; note_leds = 8'b00000110; end //D#
5: begin factor = 7587; note_leds = 8'b00000100; end //E
6: begin factor = 7163; note_leds = 8'b00001000; end //F
7: begin factor = 6766; note_leds = 8'b00011000; end //F#
8: begin factor = 6378; note_leds = 8'b00010000; end //G
9: begin factor = 6017; note_leds = 8'b00110000; end //G#
10: begin factor = 5682; note_leds = 8'b00100000; end //A
11: begin factor = 5364; note_leds = 8'b01100000; end //A#
12: begin factor = 5066; note_leds = 8'b01000000; end //B
default: begin factor = 1; note_leds = 8'b00000000; end //nothing
endcase
end
reg eocnt;
reg [13:0]cnt;
eocnt <= (cnt == factor);
always @(posedge clk or posedge eocnt)
begin
if(eocnt)
cnt <= 0;
else
cnt <= cnt + 1'b1;
end
//output sound frequency
always @(posedge eocnt)
note_clock <= note_clock ^ 1'b1;
endmodule
reg [20:0]counter;
reg one_step;
begin
else
end
begin
if(nrst==1'b0)
begin
//reset
music_time <= 0;
note <= 0;
end
else
begin
if(one_step)
begin
case(music_time)
default:
//end of music
endcase
end
end
end
endmodule
module note_synt(
//output freq grid
//C 523,2511306 Hz
//C# 554,3652620 Hz
//D 587,3295358 Hz
//D# 622,2539674 Hz
//E 659,2551138 Hz
//F 698,4564629 Hz
//F# 739,9888454 Hz
//G 783,9908720 Hz
//G# 830,6093952 Hz
//A 880 Hz
//A# 932,327523 Hz
//H 987,7666025 Hz
//C 1046,502261 Hz
//divide coeff
reg [13:0]factor;
always @*
begin
case(note)
endcase
end
reg eocnt;
reg [13:0]cnt;
begin
if(eocnt)
cnt <= 0;
else
cnt <= cnt + 1'b1;
end
endmodule
